What bolt pattern do you have???????? I assume you have buds and not daytons. There are 2 bolt patterns, stud centered for the older vehicles and hub centered for the last 20 years or so, they won't interchange and these large bolt patterns and are on 5 ton suspensions and larger which are meant for only the largest tires. If you have an intermediate weight bus then you will have the small bolt pattern, smaller tires, and will have to order special wheels drilled with your bolt pattern and rim width, I doubt you can find used ones. If you have the large bolt pattern then you can find wheels all over the place. Just check with any large tow operation, they have wheels off wrecked trucks and trailers or any truck salvage. Here is a place that has plenty of wheels and if you talk to them right you can get some pretty good tires on them for a little more. Wellsville truck salvage (Kansas): 785 883 4117 You can ship these kind of bulky heavy items by Greyhound and it's reasonable (probably just the wheels, with tires would be too bulky and heavy to load) If you go to the gallery to P14 and look at my pictures, next to last pic, then you can see what the large bolt pattern looks like, it's about 11 1/4". I have seen very few busses with this bolt pattern, mostly older BB in the 76 or 84 passenger versions, most busses seem to have daytons. I was looking at an old over the road truck to buy and it had 10 alloy wheels and good tires for a few thousand dollars. You could use 4 on your bus (steels on the inside rear unless you want to change studs) and sell the rest to some other skoolie guys. My rears just fit without changing the studs if I just ran alloys on the outside, steels on the inside. Good luck, sportyrick
