lornaschinske
PEX
Iceni John said:The minimum bend radius is still an issue with PEX - can you gently heat it (such as with a hair dryer) to soften it enough to bend without buckling?
I think you would have more trouble with the vinyl stuff trying to bend it that tight, my experience is that it kinks quite easily.Typically, with standard PEX tubing, you can expect it to have a bend radius of 6 times its diameter. Therefore, if you have 1/2" PEX tubing, the tubing will have a bed radius of about 3", making PEX tubing extremely flexible, compared to other types of tubing.
