Ourversionoflife3
Hey everybody. We're in the midst of sealing off water entry points to our bus and are getting stumped.
We've already done the obvious: Remove and reseal every window, put seam sealer on every seam and rivet on the roof, and removed the emergency hatches and put in Maxx Fans instead. There is no water coming in through any of the areas we've addressed, but we're seeing some water collect in an area we didn't anticipate.
It looks like water is collecting at the bottom of the side wall ribs where they meet the bottom shell of the body (the floor of the void between the outer body panels and the lower interior wall with the seat rail lip). We can't tell if the water is coming in through the body panel seems that attach to these ribs, or through rivets that attach the panels to these ribs, or both, or something totally different that we aren't seeing.
The water isn't getting to the main floor space but we don't want it in the void and creating mold on the insulation we plan to put in there.
Has anyone else seen this? What did you seal up to stop it and what type of sealant did you use?
Cheers,
Drew
Cheers,
Drew
