SkoolieSound
- Joined
- Oct 28, 2014
- Posts
- 1
Hey all! I've been visiting this site for the past several months as I convert my shortest of the short buses (1990 GMC Vandura 3500). Thanks all for the great wealth of information! After months of lurking, I've finally run across a conversion question that I haven't been able to answer though searches.
I designed Bessie's build with an even weight distribution in mind, but I'm converting the bus in stages and inadvertently designed it so that the weighted portions of the right side of the bus won't be completed until much later down the road when I install the water holding tanks and fridge. There's a 300-400lb discrepancy between the two sides of the bus and it will be that way for several months to a year. Do I need to be concerned about this amount of weight, or is it a nominal difference? Thanks!
