Hello!
I have just purchased a 1998 international 3800 (t444e). The bus runs an drives great, except for one thing.
When I slow down and go to turn, it slows down perfectly and then when I start turning the wheel a lot like to turn into a driveway or street, the brake pressure light comes on and I hear what sounds like the brake boost pump (same sound that I hear if I turn the bus off and hit the brake pedal) and the steering gets extremely hard to finish turning like the power steering pump stops working or something. It only does this when im going real slow and turning. When im on the highway it goes good and sometimes it turns good when im pulling it out of my driveway and things like that. I also noticed, if I turn the bus on, let it sit for a couple of minutes, and then try to turn the wheel really sharp when sitting still, it makes that brake pressure light come on as well as that sound just like when trying to make slow turns. So when the wheel hits a certain threshold it starts happening.
I have checked brake and power steering fluid, everything looks good in those. It has the hydraulic brakes btw.
If someone could give me some ideas or maybe you have had this same issue, any help would be greatly appreciated!
