So I will admit, I jumped into a purchase before doing sufficient research. I found a bus very close to home which looked like a good deal and purchased before fully researching it.
What I got: 2013 International PB10500, 168k miles, 53 passenger, little to no rust, overall good shape physically, good tires, but intermittent issue with fuel pressure (I’m guessing it’s the high pressure pump wiring harness but haven’t dug into yet), and as the title says, it has the maxxforce 7 engine.
My intended use is to convert to camper for maybe a handful of trips each year, either locally or in the mountains.
Now that I understand this engines reputation, I see a few options:
1. spend the time and effort to convert this one and do what I can to improve the probability the engine holds out for us for how little we will be using it.
2. Part out or send to scrap yard and probably recover what I’ve invested in it so far.
3. Since the structure is in great shape, start looking for a totaled truck with a Cummins or DT466 which I could put in this bus.
I’m not intimidated by projects, so the idea of looking for a donor engine is appealing to me, and that way I can start working on the conversion now and worry about engine later, but if there is something I’m overlooking when considering doing a power plant swap, I’d rather figure that out sooner than later.
Anyway, thanks in advance for any guidance.
