Diesel Dan said:It enables you to work on the top of the tank without having to drop the tank, which would be a huge hassle. So, for instance, if you had an in-tank fuel pump go bad, or a fuel line break, or ... things like that.
ThePimentals said:...so when I lay my floor do you think I should leave access to it? That's easy enough, so it would be worth it right?
keith said:no just cover the hole up.and someday youll fine out![]()
why its there gezzzzzzzzzzzzzz
