Will-SKO
I drove 66,000# GVW trucks pulling howitzers in the marines. The old M813 5-ton 6x6 had air over hydraulics and the M923 6x6 5-ton had full air. The M198 howitzer had air/hydraulic. They both had the same 14-liter, nastily ass-pirated 250hp Cummins. The 813 was a 5-speed manual and the 923 was a 5-speed Allison auto. Driving it, the 813 had more power because the torque converter on the 923 was sucking it up. The 923 was better because the cab was a lot wider inside. In neither case did the brakes make a bit of difference. The hydraulics were just as good as the air.
The main issue that is being disregarded here is the benefit of a disc over a drum. A drum is an oven. A schoolbus doesn't have an exhaust brake, generally, and drum brakes are heat ovens. Once the brakes get hot, that's it. You can have lots of pedal pressure, but it isn't slowing you down.
I don't think drum brakes are allowed on heavy-duty trucks in Europe anymore because their stopping distance is much less than discs. Whatever applies pressure to the shoe or pad doesn't matter. It's a matter of convenience. A diesel makes no vacuum so you need a pump. A gasser makes vacuum and a resevoir is cheaper than a pump. The steering pump (hydra-boost) or an electric pump (my bus) can be used to boost hydraulic pressure. The real issue is disc or drum and disc is the clear winner.
