I'd luv to get into veggie oil for my diesel pusher...I've looked into it enough to know that its viable. While true that a bus takes a lot of fuel, most of my (anticipated) travels are fairly local, at least in the short term. The more folks that get into this market the more veggie fuel will be readily available (and cheaper). And besides, the whole point of veggie oil as alternative fuel is to reduce the consumption of petroleum fuels, so environmentally its more of an advantage to burn waste oil in a bus than in a small truck that's already fuel efficient. According to CNN, the price of a gallon of gas could reach $3 by the end of summer...
I'm a believer in the impact one little tiny bus has on the entire planet, I guess. My mileage may be minimal, but the symbolic impact is hard to measure. Plus I've heard that veggie fueled engines smell like french fries, which beats diesel exhaust any day. Mainly I like the challenge...
The theory sounds good. You start the engine using regular diesel and at some point open a fuel valve to a veggie drum, which acts as a secondary fuel tank.
I've heard a couple of 'buts': Newer diesel engines tend to be built with soft seals and hoses that are chemically compatible with bio-fuel. Not likely with my rig (the bus is a 1980 Gillig; the engine is a rebuilt Cat 3208 that was installed in 1998). So before any fuel system change I'd want a knowledgeable mechanic to look over and make the needed changes and/or assure me my engine is compatible. That's a lot to ask on a second-hand bus. According to Caterpiller literature a "B20" grade of biofuel (20% veggie/80% diesel) is compatible with all stock engines. "B100" (100% veggie fuel) isn't.
The other issue is the waste oil temp--the stuff gets quite viscous at low temps (<40F ?)...I've seen conversions that use the hot engine cooling water, but I'd need somebody to plumb that (or at least help me out).
Then of course you need to find some suitable fast-food grease outlets, which is the easy part...plus good P.R. for them if you do it right.
How to qualify, pump, and filter the stuff is minor, particularly in winter...also granted that pumping 20 gallons at a time could get to be a challenge...
Anybody with more info I'd love to hear it.
