me too. i ony fill up at the pump with "turbo diesel"...banadictaustin said:I used turbo diesel in my vehicle because it has additive in it for better mileage and long life for engine. I think you Just go with whatever the car manufacturer recommends it helps in many ways.
crazycal said:banadictaustin said:I used turbo diesel in my vehicle because it has additive in it for better mileage and long life for engine. I think you Just go with whatever the car manufacturer recommends it helps in many ways.
I read through some of this guy's posts. Strange stuff. Can't figure it out.
I will be running some percentage of a waste motor oil/ regular gasoline mix with diesel. I've running wmo blends for over 5 years in my diesel truck,so I have a pretty good body of experience and the equipment needed to de-water, filter and blend wmo fuels.
Share your setup.
OK, I will. But I'll do in the alternative fuel thread.
http://www.skoolie.net/forums/f17/b...roleum-products-as-fuel-11106.html#post111495
I've tried diesel once or twice in my 8.2 T but mostly furnace oil, used fry oil (canola) or auto tranny fluid and hyd oil. Basically mix anything with furnace oil at a 3 to 1 ratio. 60L of furnace and 20L of used canola, etc. I've burnt a 45gal drum of veg based hyd oil straight. No issues with power or milage. As mentioned before, diesel fuel was "invented" many years after Rudolf Diesel was found floating in the English Channel. Surface combustion engines were designed to run on local oils. Rape seed, palm, coconut, whatever the country has.
Taking your time.. getting the oil clean... getting it thinned down... only running on it when at temp... all goes into having an easy time with it. I learned the hard way a few times... Over the last few years, it's been smooth sailing though.
I'll be dual fueling my shorty...
I currently run 2 of these engines on centrifuged and blended waste motor oil (and any other oil I can get my hands on that isn't veggie).
My other RV is a bobbed M35a2. The multi-fuel engine in it is perfect for wmo, and I've run it for years with no problems. I don't have a centrifuge, I've been using heat (the Georgia sunshine) and gravity to de-water and filter socks down to 1 micron to strain out the crud. With a centi. you don't have to worry about de-water.
I have been very lucky to be able to get a lot of reg gasoline AND JP4 jet fuel for thinning.
What are you using for a centrifuge? I'd really like to build one one day. I'm a little leery about using wmo in my 2000 GMC Short bus with the 6.5 Turbo Diesel because of the efi.
one of the things about diesels is they will burn oil and are happy doing it.. im guessing that makes doing alternative fuels a bit easier?
after all a runaway diesel is a diesel running quite happily (for a shrt time) on its own oil...
makes a lot of smoke but it runs..
I use one of the oil filter style pump driven centrifuges from PA Biodiesel.
