cadillackid
the only reason I could think of that WMO may not work in an electronic engine is that you have no easy way to change the metering of the fuel going in.. with mechanical you can adjust your fuel screws / plate for more or less fuel depending on how you manufacture your fuel.. the electronic systems dont have much support for tuning.. at least not at the Medium duty level like our busses.. (cummins 5.9 maybe?)..
if your manufactured fuel is very close in BTU output and viscosity to diesel when its going into the system then id see no reason why it cant run in a computerized diesel..
Most of the diesels we have here on the forum have no feedback.. they are simply a pre-programmed curve based on temperatures / speed / engine load.. unlike a gasoline engine where an O2 sensor and knock sensor are often employed to help determine how well the engine is running and adjust fueling accordingly on the fly.. I think somewhere ive seen mention of knock sensors in diesels for fuel timing on-the-fly but cant remember where I read it..
in the HEUI engine world (DT-466E, Cat-3126, T444E, VT365) to name a few there was some work in which the ICP sensor value was manufactured to run up the HPOP pressure and fuel heavier.. as well as manufactured Crank position sensor to control fuel timing.. I wasnt involved in that project and I could see several areas where it went wrong... ive done alot of ECM hacking over the years on Gas cars.. havent done alot yet on diesel busses.. im just getting started by altering J1939 comms between modules.....
and touch propane
just for a little oomph!!!
getting up those hills :biggrin:
