frank-id
After much study and many trials, there is no finite answer. The Crown Cummins engine do not take well to small electric heaters. I built a lower hose heater from a high wattage block heater. The device worked but after lots of time and dollars for power. Raising the temp of a big diesel engine from 20-30 degrees to just 50 degrees requires lots of watts. The engine is trying to cool at the same time thru the radiator. Over the road trucks use a block heater that heats only the block and the thermostat traps the warm coolant in the block. The factory location for a block heater is not a good place for a 80 degree tilt engine. A modern coolant heater will work great for starting a cold engine but the coolant heaters are very expensive at about $15-2300, and lots of labor. I'm about finished installing a unit in my Crown. I got my unit from a kid in Canada for about $800 plus $125 shipping. Most diesel engines are a bit fussy starting at low temps. The easiest and cheapest engine starting is with careful use of either or gasoline vapors. When desperate to start a cold diesel engine, get about a pint of gasoline and a large shop towel. Pour the gasoline on the cloth and saturate same. Have a helper operate starter. Place wet cloth near intake or air cleaner while slowly turning cloth to allow vapors to be drawn into engine. When cloth is removed from intake, engine may begin to cease running, so be prepared to place cloth near engine intake repeatedly. After a period, engine will continue to run without any aid. Never allow liquid gasoline to enter a dieselk engine, as the engine may accelerate to a very high RPM and self destruct. Frank
