What Would You Do?
o1marc
Dec 23, 2017
10,479
Dawsonville, Ga.
So my genset harness has large connectors on each end. My dilemma is should I cut a big hole in the floor to accept the connector, or cut the wires and utilize a much smaller hole, splice wires back together.
Cut a hole, pull wire and patch around it. Can you find a “gasket” that would work? Maybe a rubber plug used for plumbing?
Or, can you get the connectors out of the plug? Are there little plastic tabs holding the connectors in that you can push with a needle and pull out, then reassemble?
I would personally mark each wire (different coloured marker perhaps?) and the connector then pop the connector pins out. Usually you can slide a safety pin between the crimped connector on the wire to compress the detent and pull it out.
There are many designs, but they're mostly similar to this one:
attachment.php
Sometimes the "tang" is on the crimped wire piece. Sometimes it's on the connector housing.
Hey, thanks for that. A small rubber plug I can slit to get the wires in and then install in the hole. :thumb:
:Thanx:
