C00LR
Mine has an RV door. It works fine no problem. I think that if I were in your shoes I wouldnt use a wood door. I might go with a steel mobile home door or an RV door. Do they make the mobile home doors small enough to fit in the opening without major mods? I'm not crazy about the RV door in mine. It locks and all but wouldnt be much work to break in. But then again, it keeps the honest people out and if someone is determined to get in there they will. Look at that big windshield right there. But that subject is covered in another thread. You need to make sure you put a decent size window and install it as high as possible. I have an awesome blind spot out the right side and sometimes kind of have to lean over to see out the window so I am sure I am not going to pull out in front of someone when turning.
In the pics below, you can see the view out my window isnt very good. Of course your looking at the neighbors house and cant see what I see when out and about but you get the idea. I also sort of wish there was a window down low as well.
