IDoMy0wnRacing
450-500 ft/lb with dry threads for both 3/4-16, and 1-1/8-16, .875" spherical radius nuts (Also known as "ball seat" nuts).
Sorry I confused the issue...I bought a torque multiplier to loosen and was looking at that torque device for tightening lug nuts. I should have been more clear
Torque Wrench, 3/4 drive with a rating of 100 ft-lbs to 650 ft-lbs.
Something along the lines of this: Torque Wrench 3/4-Inch Drive(100-650 ft-lbs/135-880Nm)
I picked up a Impact Socket Adapter Set to use the sockets that came with my Torque Multiplier with the 3/4 Torque Wrench that have..
That's the information I was looking for. Thank you. I didn't feel comfortable cleaning out the excess and sealing it up. A 5 gallon tub of it is over $500, I'll check around town like you said...with my cool whip tub![]()
Yup, crazy expensive. Our 15 gallon drum is 1/2 full after 10 years. Little goes a long way in a normal fleet.
Just another head up..... extra note, don't forget to pack (or sink) the bearings like normal grease.
When this system first came out in the 90's we had a rash of burn ups because mechanics were packing bearing only and leaving the hub belly's empty as you might with normal grease. It flowed/spun away into empty hub cavities and starved the bearings. You need to pack the bearings AND fill hub belly/cavities. Fill meaning a puddle from race to race, not pump-out-all-the-air full.
I was paranoid enough I'd put an inch or two of fluid grease in the hub cap and did one reeeeally fast manuever to slap the cap on before it could flow away. Only if I had a hub cap felt gasket... if just using silicone.... better not try this or you'll be leaking again if the grease flows and screws your silicone bead. It's about the consistency of cool, coagulated, gravy. Good Luck man!!!
do you prefer this over oil bath? ive got oil bath on 2 of my busses and have had zero issues other than a couple wheel seal leaks I caught early as they are checked often.. (daily on a trip and at any stop I make I look for signs of leakage)..
my old 1978 Loadstar has standard grease hubs that have stayed full and clean.. I repacked them once a couple years ago as they looked a bit dirty then..
im guessing the standard grease hibs are a candidate for Semi-fluid but the oil bath need to stay oil bath?
I've been reading up on this subject for a little bit now and have a much better understanding. Although I'm not sure what brand is in my wheels now (color) I find that SHC 007 is red, the Champion 00 I bought is amber and there are variations of each.
The NLGI (National Lubricating Grease Institute) ratings are key here. This is a cold consistency rating and what I currently have is #00 (semi-fluid, lithium based) with a 460 weight. NLGI ratings are from #00 to #4, #4 being very stiff. They are rated for extreme pressure and suitable for truck hubs.
I didn't know any of this when I cleaned out all the extra grease in my hubs and then was told the extra is absolutely necessary to avoid grease starvation due to centrifugal forces. I'm going to pack (fill) these like they were before and with a new gasket, torque the bolts to spec and hope for no leaks
If the leak is coming from the inner wheel seal, behind the wheel bearings themselves, this could indicate more serious damage, possibly due to wear on the wheel bearings or seals themselves. Replacing the inner seal would require more extensive disassembly of the wheel bearing assembly.It sounds like your bus has oil-lubricated front wheel bearings kit, and the leak is likely due to a failing gasket or seal on the wheel bearing hub cover.In many cases, you can remove the wheel bearing hub cover, clean the mating surfaces, and replace the gasket or apply a fresh bead of gasket sealant (if applicable). However, if the leak is from the inner wheel seal (behind the bearings), it will require more extensive work.
