gs1949
OK, so I'm getting ready to paint the bus, which means getting everything I need.. And I think I will just paint the roof at first, because it's the most important; so I think I'll put a primer and 2 top coats on the roof before I do the rest of the bus..
So what I'm wondering now is whether I should put seam sealer on the seams, and maybe on the rows of rivets where there is no seam between the panels too. I have several of those too.
So I've been looking at seam sealers today. 3M tends to be very expensive. Dynatron is noticeably less and has very good reviews too.
https://www.amazon.com/Dynatron-570-Sealer-White-Caulk/dp/B004BRG494/ref=sr_1_31
And then there's the paint on stuff:
https://www.amazon.com/3M-08656-Brushable-Seam-Sealer/dp/B000PEW4I2/ref=sr_1_3
OR
https://www.amazon.com/Dynatron-552-Brushable-Gray-Sealer/dp/B004BYEU5C/ref=sr_1_22
There's no signs of any leaks in the roof of the bus that I can see. But I'm not sure how much that means. I know there was a pretty good leak around the rear emergency hatch because it rained almost 7 inches that first weekend after I brought it down to the coast in early April. There was waterlogged fiberglass, but it hasn't rained hard since and I can't see where the water came from before it got absorbed by the fiberglass. I can just tell it came from somewhere near the hatch. No water around the other hatch. but I am nearly ready to get rid of both of them and will do that before I paint.
So basically I am wondering whether I should use painted or caulked seam sealer. I think the easiest would probably be just running a bead with the caulking gun.
And I am also wondering if I might not be missing something that could be obvious to someone with more experience.
And maybe some help estimating. I have about 9 or 10 seams plus maybe 4 rows of rivets where there is no seam.
Comments appreciated. Thanks
OR
