Tango-SKO
Propane tanks must be very well vented and really do not belong in any kind of enclosure. Even a tiny, slow leak could cause an explosive build up of gas.
Ive been reading through the propane threads and surprised how unclear the recommendations are.
Can someone explain how mounting two tanks in the under-storage compartment of my bus (using something like this would need to be "vented"
The under-storage is pretty water tight so adding holes seems counter intuitive.
I'm also planning on putting my battery bank down there on a slide out. These can be far apart as the under-storage is nearly 10' wide and runs the whole width of the bus.
I mounted 2 ea 24gal tanks & built a cage around them with expanded metal
Love that set up, have any more detail pics?
Plan to mount a couple horizontal forklift propane tanks under the bus. These have a metal shroud around the valve and the gage.
Does anyone see a problem using those for bus propane storage?
Great thread btw!![]()
Thanks for that info.Propane powered forklifts primarily use 33 pound cylinders as their fuel source and are equipped for liquid service. They are not designed to be used for typical vapor use.
