wrenchtech
I have noticed that a lot of folks like to build with the same materials and methods they would use in the interior of a conventional residence. I suppose that is the path of least resistance, to go with the techniques and materials that we are most familiar with and which are cheap and easy to acquire. I see people building out their interiors with 2x framing lumber and drywall and basically recreating the design of homes built years ago when carpenters did what they knew best, turn a pile of lumber into finished dwelling.
I’m thinking that if weight matters, there may be lesions to be learned from examples of aircraft, and the trailer industry. I am looking for ideas for using metal channel like trailer walls are made with and finishing with pre-painted aluminum sheets or fiberglass reinforced panel (FRP) and accenting with strips of stainless steel or aluminum. Maybe even pop-riveting cheap Luan plywood ($14/sheet) to sheet metal studs. I am already leaning towards furring out my exterior walls with 2 x 2 (nominal) metal studs which would give me 3 1/2 inches total wall thickness. For insulation It looks like foam is the only choice for the climates where temperatures go sub-freezing. For days on end. I just can’t see how anything else can work. Any kind of permeable insulation like mineral wool or fiberglass bats is going to be a problem. You cannot put a vapor barrier between the living space and the insulation because every insulated space has to have some way to dry, to rid it self of the moisture which will inevitably get in either from leaky windows, screw penetrations or whatever. The wall certainly are not going to dry towards the exterior. Moisture is not going to pass through the sheet metal outer panels and if you put a vapor barrier on the inner face of the wall you will be trapping that moisture in the wall where it is going to cause rust or grow mold. So it’s either foam or spend winters in warm climates.
