I was planning on towing a 16' single axel trailer with my smart car on it but lately I have had second thoughts about it. It only takes one time to have a catastrophic incident with a trailer. I know it probably wouldn't happen, but Im not sure I want to take that chance...I can work around the benefits of taking the trailer and car but I cant work around a trailer coming unhitched and the White knuckles that I will surely have by taking it. Any thoughts on this dilemma Im facing...
You are talking about as guarantee! NOT towing a trailer will guarantee you DOP NOT have a failure! This is, of course, an absolute. But then you sacrifice your guarantee when you climb behind the wheel, however, then you take measures to make sure you MINIMIZE the threat of failure. check you tires, are they inflated correctly, have enough tread, how OLD are they? Fluids! Do I have enough engine oil, transmission fluid, differential gear lube, COOLANT! Did I change the Fluids recently enough or should I change them now, are they at the correct level, did I use the correct type of fluid per my application.
This is true every time you operate/navigate a vehicle down the highways and by ways of this nation. THAT is the bad news. The GOOD news is; it is easier when applied to a trailer. First of all, NEVER tow a trailer, with a vehicle, on board, that does NOT have brakes ON THE TRAILER. Make sure you secure the vehicle to the trailer so it moves WITH the trailer. The vehicle should NOT move independently of the trailer. Do NOT secure the vehicle at the wheels, secure the FRAME of the vehicle to the FRAME of the trailer. THEN check your hitch, then check your brakes, tires and brake function, make sure when you pull the 'deadman switch' the brakes actuate and stop the trailer, then check your lights and light functions! The KEY here is called Preventive Maintenance. You do the PM on your ride, RIGHT? The same is true for a trailer. so the PM and you have Peace of Mind. Use an additional camera/monitor to be able to see/watch the trailer and it is smooth sailing, so to speak! You can't buy confidence, you MAKE it!!
