Idaho Mike
2006 Navistar 4300 with DT466 box truck starts and idles perfect, take it up to 15-2000 rpms and starts missing, blowing white smoke, let it go back to idle and it runs fine. I get the PID94 FMI 1 code which is a lack of fuel pressure... What I have done, replaced cannister check valve, new fuel filter, cleaned strainer, changed fuel line grommets, new fuel pump. This started while going down hill and decelerating, when at the bottom of the hill thats when it starts to smoke real bad then clear up and run fine, this continually got worse to where I can't run it and broke down on the side of the road outside of Laramie Wyoming. I checked the coolant level and it's fine, no fuel or coolant in the oil either. Fuel pressure on analyzer 48psi
