I'm at the point where it'll be so much easier to remove my two front heater cores. They have just been such a headache and it'll save so much time, space, and stress to remove them and loop coolant line from thermostat straight back to the water pump. I have fomo on getting that "free" heat though while driving.
My bus is very well insulated. 2 inch foam board on the floor, including the driver area, and 3 inch spray foam on walls and ceiling. I have two fans in the dash I can point at the windshield if need be.
My question is can I be warm driving with this setup relying on the deisel heater instead of the heater cores?
I've also seen people mention running the heaters to keep the engine temp down in the summer. Does that matter if the line is just looped back to the pump?
