TheHubbardBus
We need rivets for two purposes at the moment: sheet metal patches to replace emergency hatches / vents, and at least a couple rivets that go through the outer sheet metal roof into the steel ribs (replacing ones missing). I've searched the forum for questions on riveting (never done it before), & hit up other resources, but still have a ton of questions:
1) Since we have the interior skin off, it seems the best bet would be solid rivets. True? If so, are there variations of solid, & what would you recommend?
2) For the appropriate rivets, recommend me a gun (please). I've got a compressor with a pretty large tank.
3) Assuming solid rivets, is 'bucking' something my wife should be capable of? How much, if any, strength does it require? Also, is a bucking bar necessary, or something easy to improvise from common tools?
4) 'Wet' installs... what sealant should I use?
5) What do you use to seal roof patches with? Do you apply it all at once after drilling holes? Do you have to rush before it sets?
6) clecos.... 'nice to have' or 'stupid to not use'?
