Brad_SwiftFur
Time to crawl under the bus and give the suspension a good inspection. I would suspect a broken leaf spring, or if it's an air ride, a deflated air bag.
Ok so y is no one talking about 1300lbs of engine and transmission offset 6” to the passenger side of the e series vans.?!?!?!
-------------------------Any way u can show me how u got to the average size person #?
Any way u can show me how u got to the average size person #? The van is 70”wide center of wheels front and 144” center of front axle to center of axle. Now putting the 1300lbs in the four corners is the tricky part. So it’s 6” off center and the 970lbs starts right at the front axle and ends at the rear shackle it’s leaf spring, the rest of the weight follows it up transmission tcase
step one measure ground to body at four points... pick a point like.... um right above the tire. write down the numbers to the nearest 1/4 inch.
measure frame to ground at four points.... I would pick where the bumper bolts to the frame......... measure the frame! not bumper brackets, not bumper bolts the frame. write it down...
now sit back an look at the numbers... do the numbers indicate what your eyes and brain tell you?
If yes, then when a body corner is low the frame on that corner should also be low.
If no, figure out why.
The next step is to find the amount of weight on each wheel corner left front, right front left rear right rear.
is the saggy side the heavy side? if weights are near equal, and frame body measurements are askew in a manner that agrees with body lean, then something is bent, mismatched parts, or bad springs. To a point, shock absorbers should not be a part of this problem... even high pressure gas charged shock absorbers should not amount to much.
It is possible the whole body is askew and not sitting on the frame evenly. It is possible the body is not "square" It is possible the two corners of the bus are carrying more of the load and causing a twist that is seen more from the rear than the front.
numbers first... evaluate 2nd decide 3rd
william
I have a 2003 3800 30ft school bus with the wheel chair lift and airbags on the rear. I was missing a spacer shoe located on the forward end of the leaf spring. I replaced it but I still had the lean on the passenger side. I drove it around maybe 100 miles or so an one day I looked under the bus and the spacer shoe was hanging there ready to fall off. If anyone has an idea about this one please Holla. I am going try and air up that passenger side airbag more than the other. I will have to seperate one side from the other. I will see about putting a valve in .
The middle picture I see on top of the one leaf is a silver spacer with a bolt in it that is the part that comes loose on mine. Only thing that spacer looks like it’s on the rear side of the wheels mine is on the front side of the wheels on top of the leaf?
