nikitis
Preface:
Starting this thread for reference and education for others who may need to replace tabs in their windows.
I'm in process of replacing my windows tabs because almost all of them are broken.
Also Window tabs are VERY expensive. I've seen them as high as $40 a pop, and as low as $20 and if you need to replace all of them, we're talking costing nearly as much as a roof raise just to fix your Windows tabs which is ridiculous. I have only 16 windows, so 32 tabs x $40 = $1280 for just window tabs. $640 on the cheaper side.
SO, I will offer knowledge on Early 90's Thomas Bodies as that's what bus I have. This should be the same for any early 90's Vista Thomas buses as well, but not all. If anyone else would like to show a tutorial on here for their bus Window Tabs on their Bus types, your content is welcomed to post here.
I will also add a 3D Print Stencil FREE of charge that I will design by hand to replace your tabs. Sorry to anyone trying to sell these, but at those prices it's criminal, and with the advent of 3D printing, you no longer have a monopoly on the Window Tab Industry. I also will offer a service FREE of charge, to anyone who needs a 3D print stencil of their buses tab if you are willing to mail one to me in tact. I will model it up for you and offer the stencil so you can print your own. I would be willing to print you some for the price of the plastic which would probably be enough for a whole bus for $20 total, my prints would work for your bus, but I don't guarantee quality of smoothness of the prints as I have an older substandard printer, but they would work in your bus functionality wise. But my intent is not to make money with this but to help keep these buses ALIVE and ORIGINAL for those who wish to maintain their buses, and offer a far cheaper way to fix your Windows.
Thomas early 90's Windows. '94-'97 year Thomas Buses likely do NOT have these windows. My Windows were from 90-94 Thomas buses but bleed over to my '95 Thomas so it's a rare one. It may be the same but it likely could be different. Most of these the removal is similar as far as the tabs go, but removal of window parts may be slightly different to yours.
How To: Thomas early 90's Window Tab Replacement.
Remove Star Studded screws (You might have Square Studded screws). Both sides. Then the top comes apart. This allows you to slide the upper glass pane OUT of the frame which is what you must do to get to the tabs.
Slide out. Then on the pane you removed, there's 3 screws. Two up top, one on the bottom of the side aluminium panel. The 3rd pic here shows how the aluminium frame wraps around it. It needs to be removed to get to the tab.
Here you can see the 3rd screw by my hand.
There's kind of a felt/plastic like cover, it can be removed. Helps with sliding in the frame. Then the aluminium side frame can pop out. Exposing the rubber seal on the glass. Remove the sides on both sides. Now the tab is exposed but still won't come out just yet. There's a trick to it.
This is the end of the section of taking apart the window, and getting to the tab. Also at picture limit, so continuing on next post....
