bapos
Ok peeps....
I am on the tail end of the riveting for the outside skin. Last thing I have to do is weld in some strap steel at the top cause the skin is too short to rivet to hence me welding in metal to attach it to.
Here is my issue. I was planning on using a 24x24 window (from Lowes http://www.lowes.com/ProductDisplay...051&storeId=10151&langId=-1&productId=3118847 cause they carry them in stock on the shelf all the time but by the looks of it... they are not going to fit. The larger window in the very front is 32 7/8 wide x 21 3/4 high and the rest of them are 23 3/4 wide x 21 3/4 high.
I am not a huge fan of windows to begin with but I am sure it will need some square tubing welded in and framing on top of that to secure the window to it?
I am thinking about going to this window..... http://www.homedepot.com/Doors-Wind...splay?catalogId=10053&langId=-1&storeId=10051 . Its a special order but can be picked up at the store.
Im thinking a total of 5 windows in the bus..... 3 on the passenger side and 2 on the drivers side. They will be layed out in an alternating pattern so you can not see one window to the other.... Hope that makes sense.
I would like to avoid hacking on to the body is at all possible. If you guys have a better idea of how or what window to put in please let me know. I am collecting pieces so that when I pull the trigger it can be done.
Im curious as to what size of windows people normally use in their buses
Thanks in advance....
Bapos
Bapos
