C00LR
Ok its that time of the year to think about winterizing.
I wasnt sure if this belonged here, or the everything else forum. So I put it here. If I'm wrong, smack my hands.
I filled up my water tank and then ran a bunch into the blackwater tank and then flushed and drained the black tank, I ran the pink RV antifreeze into the fresh water tank and then ran all the water taps, hot water, and cold water. I drained the fresh tank out and the hot water tank out and have them open at the moment. I have all the water taps open at the moment as well. I will go out and close all the stuff up today. OR, should I leave them open?
I put stabilizer in the gas. Anything else that needs to be done?
Antifreeze is good. Its all new from when I did the new water pump.
I did a search and saw where someone had suggested steel wool in the exhaust pipe... WHY??
Dryer sheets around the interior... WHY??
Anything else??
Anything else??
