Hi,
I've got a 40' coach bus, and am working on getting all the electric ready before the spray foam guy comes next week.
The bus will not travel much, and will run on 30A shore power. I have an AC system setup, and in my utility closet, have an outlet with an AC to DC power converter and a fuse block.
I want a light switch at the front of the bus to turn on/off 14 small LED puck lights (.2amps each).
The issue I'm having is the switch is about 30' away from the DC fuse block, and after getting power to the 14 lights, I will have around 80' of wire in one direction.
Using a voltage drop calculator, it is suggesting 5 gauge wire!
Any ideas on what I can do? I've never seen anybody run such thick wire for LED's. Am I missing something?
Is there a way to have a switch in the middle or end of the circuit in order to cut back on that 30' trip to the switch?
Any info would be appreciated. I had 12/2 wire ready to go thinking that was overkill, now I'm not sure what to do!
