nikitis
the VIN and CIN are 2 different things..
TCM's have a model number (like A41,A51,A59, etc) and also have a Part number.. thats for the HARDWARE itself...
the program within the TCM is the firmware and also the calibration.. the CIN is the calibration ID Number... this is where the shift tables, max RPM, throttle type, and customer modifiable values are stored like gear ratios and whether certainputs are turned on or not..
the label on the outside of a TCM is the base calibration parameters, 6 speed capable TCMs are supposed to be stamped with a primary mode of 1-6S1, 5 speed units will be stamped 1-5S1 typically.. the throttle type is generally J1939 or "auto"..
the governed RPM is important as that is the RPM the unit maxxes out at.. so if your engine only revs to 2300 max RPM foot to the floor yet you install a TCM with a 2700 RPM CIN, it will never shift to the next gear till you let off the gas pedal. likewise if you habve an engine that maxxes at 2700 RPM and you install a 2200 RPM TCM it will always shift much earlier than you want it to..
there are CIN numbers all over the interwebs and many of them show the RPM, gear pattern and throttle type.. but there are other vocations which you may not want.. ie if it requires an inhibit input for say a bucket truck where the transd expects a circuot to close from the bucket.. program that into a TCM where the wires arent even connected and it may result in you never getting out of neutral..
allison dealers can look up CIN numbers and read a report.. some of the 3rd party guys have a whole library of calibrations and the CIN printouts so when you mail them your TCM they know what you are trying to do therefore know which CIN to burn to your TCM.. I have a set of the allison programming books and there are literally 100s of options that can be set in the calibrations... most often this never needs touched as allison works directly with the manufacturers of these busses and trucks.. and provides the calibrations for their vocations.. often a completely different calibration for every gear ratio, every tire size, etc..
its important to pay attention to what you are buying..
My bus doesn't want to shift out of first sometimes, I max out RPM's, but I don't know if this is due to the engine and running in Limp Mode due to my VPM being broken or not. I just finished my King pin job and will begin working on the VPM here soon. Once fixed I'll see if the shifting fixes itself, if not I may need a TCM adjustment. All the other gears shift out fine when they are supposed to but not first to second.
and it didnt work for me.. I was too low.. I regeared shorter and now im in the similar situation.. 6th for nrmal cruising and when I need a little juice get down to 5.. but for an I6 long stroke motor you cant go wrong with that setup you have.
