01ThomasMVP
Im trying to wrap my brain around the best way to install this wood burner. If anyone sees any issues I might have in the pics please let me know. My main headache now is the best, and cheapest way to install the smokestack and chimney.
I have 1 main question: The burner is made for a house and has a 6" smokestack. However, since it'll be in a school bus, I will more than likely only be making half as big a fire that it is capable of. Therefore, do you think it will be okay if I reduce the smokestack to 4"? I'm am trying to decrease the size of the hole I have to cut into the roof.
Question 2: I know that since I am going through a ceiling that has combustible material (wood) it is recommended to have a double-wall insulated chimney pipe. Does the insulated chimney pipe also require a 2" air gap? Do you think I will be able to get away with only using a single-wall stove pipe going through the ceiling with a 2" air gap?
Feel free to ask any more specific questions and give any advice and point out all the dumb mistakes I've made. Thank you for the help.
