Would this be a good candidate for a skoolie?
8 ways are your over head lights,and yes that a good price for that model,but check it out good for a 99 model the price is about $5000 or 7,so i would check it out good.if it just came off a school dis this pass yr than it could be ok, :? :?
the renegade :D :D :D
The thing on the rear directs the wind down the back windows to clear them on crud when it is raining or snowing. If you don't have that the rear of the bus will become caked with dirt in the winter.
If it is mechanically sound & there are no obvious problems I would consider it! Nice bus, the basement storage is a bonus & the fact it is a 99 is awesome... Good luck & keep us informed in your decision!! :D
Jonathan
"The bus has automatic chains installed"
That sounds great! But whats are AUTOMATIC chains?? Something to do with automaticly chaining the tires in snow???? I bet the Ice Road Truckers would love to see something like that! OK But seriously.... what are automatic chains??
Hey, a question I can answer! :D
My bus also has automatic chains, and I crawled under there and figured out how they work one day. On my bus, they are actuated via a pneumatic setup (air).
When activated, the arm swings down. The arm has a disc on the end with lengths of chain hanging from the disc. The disc will be approximately parallel to the ground, and really close to the rear tires when engaged, causing a chain to get pulled under the tire. The rotation of the tire will cause the chain to end up coming out from behind the tire, turning the disc, thus swinging more chains into position. They're close enough to each other that you will end up with more than 1 chain under the tire at a time.
My bus had a sticker that said to only use the chains at low speed, and to be careful when braking with the chains engaged. Seems to me that "real" chains wrapped around the tires don't have these same warnings. Unfortunately, I don't know *why* this warning exists. I can say that the automatic chains are helpful when spinning tires on wet grass. :D
The chains make rattling noises hanging out back there. From behind, it looks like you're dragging something.
Here are some interesting links related to automatic chains:
http://www.insta-chain.com/
http://www.onspot.com/indhisfr.htm
I hope this helps,
jim
Anyone know where to get a spoiler like that? I sure would like to fill in that hole in the air behind me. I can feel my rig picking up speed whenever the "bow wave" of air fills that hole when a semi passes me on the highway.
I'm not in a position to act yet. I was hoping someone on here could benefit from a good deal.
I did find a local bus that has caught my eye due to the $750 asking price - a 1992 International 66 passenger with DT360 and auto transmission. Unfortunately it has a minor body rust problem. Otherwise it is real nice. It is going to be junked for scrap price in 2 weeks if they don't find a buyer. I cringe to think of scrapping that fine working powerplant. I've even thought about getting it just to pull the engine for a home electric generator. I could then scrap the carcas to get back my initial investment.
My dream rig is a Thomas HDX pusher with a Cat engine and storage.
It's in my small town here in Wisconsin. They are actually getting ready to crush 6 busses (3 full size). The one I spoke of is the only auto.
