Eric von Kleist
I am about to commit to a WVO conversion. Tomorrow I am going to take a 50 gallon diesel tank off a junked truck.
I'm going to post my WVO conversion questions to this page as I go through the process, rather than on my bus conversion thread, since this is a fairly specialized topic, but one that several people have expressed interest in. I figure that having it in the general conversion section will make it easier for people to find than burying it in the conversion thread for my bus.
So, here goes...
In looking at the picture, I realize that I probably can't just splice a valve in the lines at the locations that I mention.
1) The valve(s) is going to need some kind of support bracket. Especially if it is a valve manifold as below in 2.
2) I'm probably not going to have two single valves (3 way), but instead some kind of valve manifold that will electronically switch.... No, cancel that. I want 2 simple valves with mechanical actuations from inside on the dashboard, like lawnmower throttles. They would be cheap and give me better control over the fuel flow and return switching. Mainly they would be cheap.
3) The hose coming from the filter looks like some kind of industrially manufactured high pressure hose, and I probably can't just cut it and splice something in...it may need special fittings swaged on at any attachment point.
Has anyone drilled on their main frame rails before? Is it going to be hard to drill the 4 mounting holes for the fuel tank mount bolts? I drilled my rear bumper for a quickie hitch attachment, but I'm suspecting that the frame rails are going to be heat treated. I need to drill 4 holes to mount the fuel tank that I'm getting...tomorrow! Woot!
Any suggestions or comments? (Lapeer, that's your cue to chime in....)
So, here goes...
