Hi.
I have been reading and studying many threads about the subjet and I have few questions, the threads that I read are :
Big thread lots of info
Somewhereinusa design
Alde systems
So Basically I have my bus ready to do the subfloor and I decided to go with hydronic heat so I was about to buy the materials and decide to stop and ask to people with experience before I regret it.
The system I want to build is basically like somewhereintheusa but just one zone and no additional heaters , just the floor.
The questions :
1.- I was going to build a frame, put foam insulation and then plywood = should I do 1 inch pink foam, then aluminium reflective pex plates and then more foam and then plywood on top or can I just get thicker pink foam and use a router to make a channel to route the pex through ? what will be the best way to do it ? is it better to have a reflective surface ?
2.- My bus is 22 ft long , what diameter pex should I use if I use a system with and espar diesel coolant heater , how do I calculate that ? ( since the system is just one zone I didn't know if I need 1 inch pex or less).
3.- is it recommended to use a storage tank with an element inside ?
4.- If I want to heat the engine can I just use a 3 way valve and route hot coolant/glycol to the engine or is it a different liquid used in for the hydronic heating ? ( instead of using a heat exchanger ?)
5.- is there any rules on how apart the pex has to be when routing each row ?
6.- If I use an espar coolant heater do I still need to a recirculating pump for short bus?
7.- in the case of using a heat exchanger for coolant heating do you install it inside or outside of the bus ?
8.- What is a recommended heat exchanger that is safe to use to heat potable water ?
I think this is for now, sorry for the many questions.
Thanks.
Alde systems
The questions :
Thanks.
