Yet another hydronic heat question?
Don't worry about being critical. I do tend to overthink things. Glad to hear you haven't had any defrosting problems. I havn't driven mine in really cold temps yet so I didn't know what it would do.
Since you have the multiple heating zones in your system it makes sense for the hydronic 10 to run continuously and to control the heat with the circulation pumps. I think this is how a house with a central boiler and zone heat is set up. Since I will have only one zone. I would like to set it up so that the hydronic 10 could shut off and start up to maintain a preset temp.
I have the 7 day timer as well. I was reading in the hydronic 10 manual that the timer sends a 12v or 24v signal to the controller on the heater to turn it on. The burner will remain on until the signal is turned off. When the signal turns off then the burner shuts off and the heater goes into cool down. There is an option for a simple push pull switch to turn the heater on and off in the wiring diagram. I think this could be replaced by a thermostat. I agree that I wouldn't want to short cycle the heater by having it constantly turning on and off. I think this would lead to soot build up in the combustion chamber. I think that by wiring a timing relay between the thermostat and the controller the burner could be ran for a preset minimum amount of time.
My water heater and water tanks will be mounted inside the bus to avoid freezing.
Thanks
Ted
so 5 years since to give any update on this....sorry.
This thing called "life" gets in the way and changes priorities, desires, ideas, and such.
I started working on the bus again after all these years and I will be installing the heat finally this winter, plus many other things.
After re-reading the thread there is one question I need an answer to.
The engine coolant temp goes up to like 200F and which is more than what is recommended for pex I believe, so should I be using a diverter valve to mix cool water on the heating loop?
When driving in summer to avoid water flow by osmosis should I install a valve at the "out" of the heat exchanger to avoid flow?
in your diagram @somewhereinusa I do not see any diverter valves or maybe you control this by hand?
There is such a thing called a mixing valve, it has an alcohol bulb that you put in your supply line and it can mix your cooled return with your hot supply to keep the temp under a specific number. I believe they are adjustable.
