You need to build safety into your conversion
Skunky Bus,
Noticed you live in Omaha. I do too. Go Big Red! I'm very knew to the skoolie community and am wanting to buy a bus to start converting. Would love to buy ya a coffee sometime and pick your brain if you're up to it. You can PM me at my email which is just my username @outlook.com. correspondence there would be fine too if you don't want to meet. Just wondering about Nebraska's particular licensing and insurance hurdles I may be crossing and maybe a few other things.
Thank you!
Skunky Bus,
Thank you!
I just left Omaha last Saturday :smile: Was there for 3 weeks. Met a fellow skoolie there, Lee. I hope you guys hook up!
Sandi
As well as in the engine bay for us REs, and behind any propane appliances.
good call in engine bay! I'm gonna grab an extra for back there.
side note scooter did you read my thread on the tensioner? if not I could use advice.
So I belong to a FB group where the owners of this bus belong. They built safely. The passengers were all belted in to Chevy Tahoe seats that were mounted to legs and bolted through the floor. That was my plan for my build and am confident now.
Out of curiosity...do you know if the bolts were directly into the sheet metal floor or were they bolted through the sheet metal floor and through additional steel supports below? Thank you.
You can bolt seat belts through the sheet metal floor with grade 8 bolts and use seat belt washers on the bottom . These washers are heavier and large diameter. Use the correct size for your bolts and the largest bolts your seat frames will handle without modification.
Seat belt washers are sold under that name.
Christopher
^^^what he said lol
Christopher
Smoke detectors were mentioned.. On our last glampout the diesel air heater was having issues and wasn't running clean, the CO detector sounded off nicely. I turned off the heater and fired up a Buddy unit that had been sitting for quite a while, the dust on the element had to burn off, that set off the smoke detector!
Good system check, all passed.
Yeah a lot of folks go for aesthetics vs practicality.
I'll have a full wall behind the "cab".
How are you building your wall behind the “cab”? I feel this is the safest route to go. Are your seats mounted to the bus framework or the metal floor? My passenger seats (behind drive not next to) would have 2 rear facing car seats with a LATCH system.
